OSC with new Mac OS
OSC with new Mac OS
Unread post by cmodica » 13 Jul 2026, 10:56
Does anyone use the OSC protocol with Mac OS? I'm talking about the newer operating systems that came after Mac OS X.
I tried using a shared connection and Touch OSC on iOS. The Touch OSC app successfully receives the messages sent by Usine, but none of the data changes on the Touch OSC screen.
Can anyone help me?
Unread post by cmodica » 13 Jul 2026, 12:05
Sorry, it was a config problem on touch OSC.
Thanks to delete this post.
Unread post by oli_lab » 13 Jul 2026, 12:10
I am not a fluent mac user, but I may help :
Did you set up the incoming open port in Usine as the same as the outgoing port in touch OSC ?
then you should check these ports are open in MAC : https://www.hostmyapple.com/blog/mac-fi ... like-a-pro
there is an app for that, or you could use command line directly from Usine with the module "system shell command" https://www.brainmodular.com/manuals/hh ... ll-command
this last bit should be very handy as you can include this command in the patch using touch osc !
