Poly patch container offset
Unread post by sm_jamieson » 04 May 2026, 18:47
I've been trying to use subpatch Poly more for graphical layouts. My components are in the container. Every time poly is applied the containers end up on top of each other.
I would like a Poly setting that offsets the containers from each other in position when poly is applied instead of on top of each other. After that the containers would still be moveable as normal.
The setting might best be in the container properties e.g. "Offset container in Poly" vertical and horizontal pixels. The first poly voice container would stay where it is and the others offset by the offset setting multiplied by the (voice number - 1).
Thanks.
Unread post by oli_lab » 04 May 2026, 21:26
You can achieve this with a little bit of patching :
row of faders.usine-subpatch
(59.37 KiB) Downloaded 17 times
cheers !
