Script "Data Generator" generates even without a trigger
Charlie O.
Unread post by Charlie O. » 20 Jan 2026, 22:33
Hi everyone,
I have a problem with one of the scripts from the Browser/Modules/Data/Generators, the "Data Generator Random Pattern Array" script. It has three inputs : Array In, Generate (trigger type), and Density (data float).
The problem is that when the density fluctuates, the module generates randoms arrays, even without a trigger.
Here is the code, if somebody has an idea and can help me how to correct it ?
Code: Select all
// Random Pattern Array
// Generates a Random array of 0 or 1 values according to
// the DENSITY parameter
// Connected to a Switch Sequenced module,
// can be use to create random paterns
const NB_ARRAY_OUT = 2;
var ArrayLen : Tparameter;
var Density  : Tparameter;
var ArrayOut : array of Tparameter;
var Randomiz : TParameter;
// initialisation procedure
procedure init;
var i : integer;
begin
 ArrayLen := CreateParam('array len',ptDataField,pioInput);
 ArrayLen.Min(1);
 ArrayLen.Max(1024);
 ArrayLen.DefaultValue(8);
 ArrayLen.asInteger(8);
 Randomiz    := CreateParam('generate',ptButton,pioInput);
 Density    := CreateParam('density',ptDataFader,pioInput);
 Density.Symbol('%');
 Density.Format('%.0f');
 Density.Min(0);
 Density.Max(100);
 Density.DefaultValue(50);
 Density.asFloat(50);
 SetArraylength(ArrayOut,NB_ARRAY_OUT);
 for i := 0 to NB_ARRAY_OUT-1
 do begin
   ArrayOut[i] := CreateParam('array out '+intTostr(i),ptArray,pioOutput);
   ArrayOut[i].Length(0);
 end;
 ModuleColor($FFE91E63);
end;
// Global Variables
var vlen : integer;
var j,i : integer;
var vDens : single;
// CallBack
// Callback procedure
begin
   vDens := Density.asFloat/100;
   vlen := ArrayLen.asInteger;
   for j := 0 to NB_ARRAY_OUT-1
   do begin
     ArrayOut[j].Length(vlen);
     for i := 0 to vlen-1
     do begin
       if random < vDens
       then ArrayOut[j].asArray(i,1)
       else ArrayOut[j].asArray(i,0);
     end;
   end;
end;
Thank's a lot !
BM2F
Unread post by BM2F » 21 Jan 2026, 10:52
Hello Charlie O.
The issue was in Callback, the script compute whatever parameters changed.
You can solve it with a pass before input script (triggered by you generate trigger)
or modifie the script :
Happy patching !
Code: Select all
const NB_ARRAY_OUT = 3;
procedure Init;
var i : integer;
begin
 ArrayLen.Min(1);
 ArrayLen.Max(1024);
 Density.Min(0);
 Density.Max(100);
 do begin
 end;
end;
// Global Variables
var vlen : integer;
var j,i : integer;
var vDens : single;
// CallBack
begin
if N <> Randomiz then exit
else
   do begin
     do begin
       if random < vDens
     end;
   end;
end;
Charlie O.
Unread post by Charlie O. » 21 Jan 2026, 14:10
Hi, thank's a lot.
yes, that's what i did, filtering the unwanted random events, but that was not very efficient.
I have had to changed two lines, otherwise the script would not compile : line 40 "can't assign int32 to array of int32
I just added [ i ] to the line 40 : ArrayOut[ i ] := CreateParam('array out '+intTostr(i),ptArray,pioOutput);
and the next one 41, see below
HERE IS THE PROBLEM : the forum can't display the [ i ] correctly (without spaces), so it probably disapeared in the code of your message, and the script couldn't compile in my session.
If i add [ i ] (without space) in my script, now it works as it should.
I'm not sure i'm very clear, but there is a problem in the display of the forum.
Anyway thanks a lot mate !
Code: Select all
procedure Init;
var i : integer;
begin
ArrayLen.Min(1);
ArrayLen.Max(1024);
Density.Min(0);
Density.Max(100);
do begin
ArrayOut[i] *****problem**** := CreateParam('array out '+intTostr(i),ptArray,pioOutput);
ArrayOut[i]*****problem**** .Length(0);
end;
end;
// Global Variables
var vlen : integer;
var j,i : integer;
var vDens : single;
// CallBack
begin
else
do begin
do begin
if random < vDens
end;
end;
end;
BM2F
Unread post by BM2F » 21 Jan 2026, 15:05
I have already modify the script look at Callback section
With mine if a other input than Rendomiz change I stop the process
No problem !
Unread post by senso » 22 Jan 2026, 08:31
please use the "code" tag
Code: Select all
to paste script !
Unread post by oli_lab » 22 Jan 2026, 10:28
wasn't working, so I took the old code from the Usine distro and just add one line :
Code: Select all
if N <> Randomiz then exit //outputs will change only if trig arise
else
so the whole thing is :
Code: Select all
procedure init;
var i : integer;
begin
 ArrayLen.Min(1);
 ArrayLen.Max(1024);
 Density.Min(0);
 Density.Max(100);
 do begin
 end;
end;
// Global Variables
var vlen : integer;
var j,i : integer;
var vDens : single;
// CallBack
begin
else
   do begin
     do begin
       if random < vDens
     end;
   end;
end;
Users browsing this forum: No registered users and 250 guests
