Preset Manager that sends midi messages
Ariajazz
Unread post by Ariajazz » 11 Dec 2025, 16:39
I'm working on a workspace for controlling a keyboard that accepts midi messages. The idea is to change parameters and patches of the keyboard using HH presets. Everythig is working fine except midi messages (PROGRAM CHANGE) are not stored, I guess, in PRESET MANAGER. It does not send the midi messages when recalling presets. How do I do it?
Ariajazz
Unread post by Ariajazz » 11 Dec 2025, 23:49
Hi all. I'm stuck with my project because this issue. Does any one have a solution?
Unread post by rlgsbt » 12 Dec 2025, 07:18
Hi Ariajazz,
If you send manualy the program change from Usine, it works ? You could also use the grid.
Here is a very simple patch. You just have to put the MIDI OUT device in the rack output
MIDIprogchange.pat
(16.02 KiB) Downloaded 433 times
Unread post by grego mondo » 12 Dec 2025, 10:31
May be
If you save the program change value in a fader, you can use the fact that the preset "has change" to send it with a create midi message.
P.S. Don't forget to be as impatient for thanks than for answers
Ariajazz
Unread post by Ariajazz » 12 Dec 2025, 23:59
Thank for your reply. Your patch was very helpful. I didn't know about the PASS CHANGE module. I had to do some modifications to suit my needs, but it just works fine. Thanks again.
I'm not impatient... some times it is a matter of hurry. I do have a musical presentation tonight. Now I can do it as planned.
Users browsing this forum: Google [Bot] and 23 guests
