UserModule and MAC M4
Post by oli_lab » 24 Oct 2025, 22:40
IF someone with a MAC M4 could test those 2 modules : ADDSRV3 and phaseDistortionV3, that would be super cool.
these user modules can be found in the "Modulilab" addon (latest update).
thank you
Post by cmodica » 30 Oct 2025, 17:28
Hello Olivar.
I tested it with my new MacBook Pro M4 and it doesn't work.
Both seem to be invalid. I downloaded the latest Modulilab update (Modulilab 34) to test them.
They you for your work.
Post by oli_lab » 31 Oct 2025, 17:03
thank you,
I'll look into this matter asap,
looks like something has change on the Macos side
Post by oli_lab » 08 Nov 2025, 10:46
if someone can load the GCD module (datalab/math) into a M4 and tellsme if it is loading alrigth, that would be great !
thanx
Post by grego mondo » 09 Nov 2025, 00:52
Load all right
Post by oli_lab » 10 Nov 2025, 22:08
grego mondo wrote:
09 Nov 2025, 00:52
Load all right
did you load it in a MAC M4 ?
can you try ADDSRV3 and phaseDistortionV3 from modulilab34 ?
Post by grego mondo » 11 Nov 2025, 13:39
Yes I loaded it in a mac M4
But I'm not there (where the mac M4 belongs) anymore ...
Post by oli_lab » 11 Nov 2025, 16:47
cmodica wrote:
30 Oct 2025, 17:28
Hello Olivar.
can you try to load the GCD module (datalab/math) into a M4 and tell me if it is loading ok ?
I'm puzzled !
find out so far that M4 need ARM64e and M2 only ARM64
thanx
Post by cmodica » 16 Nov 2025, 18:36
Hi and thank you for your job !
Sorry for the late reply.
I tested on a Mac M4
ADDSRV3 and PhaseDistorsionV3 not loaded (Invalid)
load ok ! 8)
Post by oli_lab » 18 Nov 2025, 19:44
hum, it's getting very weird.
I suspect it doesn't come from the compilation settings as they are all the same. I need to be sure it comes from something else in Xcode.
I recompiled the gcd module (gcd_test) if it doesn't work >> problem with Xcode if it works>>it will mean that I have an issue with with my settings for the other module (phase distorsion V3)
thanx for your time
test251118.zip
(55.82 KiB) Downloaded 340 times
Post by cmodica » 19 Nov 2025, 10:18
No problem, I have time right now.
Sorry but I tested both and neither one loads. They appear as Invalid.
Post by oli_lab » 19 Nov 2025, 12:24
Thanx CModica
If someone with an M2 can have a try, it will clear things up
I compiled an example from the SDK and a module of mine (with clean xcode project) can you give it a try again ?
thanx
test2.zip
(117.59 KiB) Downloaded 376 times
Post by cmodica » 19 Nov 2025, 14:01
yes ! both loads well. 8)
Post by oli_lab » 19 Nov 2025, 14:56
Ok, thank you !
that is the good news,
now, the bad one :
I need to know all the modules that are not working so I can fix them.
and they are hundreds...
Post by cmodica » 19 Nov 2025, 17:21
I will try to help and test all the modules from time to time whenever I have time.
I will tell you.
Post by oli_lab » 19 Nov 2025, 17:40
thanx,
On my side, I will compile all the most recent ones and put them online
here is the list of updated modules so far : (you'll need to remove the current addons then reload them, otherwise you'll get doubles)
modulilab :
PAF (phase aligned formant)
gen wave packet V3
wavetable reader V3
phase distorsion V3
datalab :
event recorder V2
multitrack recorder :
multitrack recorder
Post by cmodica » 21 Nov 2025, 11:55
- I delete all the data_lab, moduli_lab and Multitrack recorder from the application/config/addons.
- I download the new addons from Usine - > OK.
There is in each folder, a sub folder _MACOSX -> of course, nothings loads well in MAC OS 15 with my M4
modulilab :
gen wave packet V3
wavetable reader V3
phase distorsion V3
datalab :
event recorder V2
multitrack recorder
Everything loads well. But i didn't find "gen wave packet V3" ...
Post by cmodica » 21 Nov 2025, 12:36
I have just tested a lot of modules :
All the Data_Lab are loading well. Except "ADDSR V3". The "ADDSR V2" is OK, but the V3 is invalid.
All the Moduli_Lab are loading well. But
- "Velvet Noise" and "Wave Extractor-V2" send a "(2) Error : in Process" in the Trace panel.
- Wave Recorder V2 is Invalid
- Wave Recorder V3 is OK
- OliloscPe-3ch is Invalid
- Legacy_Lab -> all OK
- MorphFilters3 -> all OK
- Multitrack recorder -> all OK
- Physic_Lab -> all OK
-RythmBox 2 -> all OK
- RythmBox1 -> all OK
Spices -> all OK
I hope it helps.
Have a nice day.
Post by oli_lab » 21 Nov 2025, 14:36
It helps hips !
Thank you, I look into that asap.
Post by oli_lab » 21 Nov 2025, 14:58
it's Oli_Lab_Wavepackets_V3
Post by oli_lab » 26 Nov 2025, 19:18
can't find those :
do you mean wavetable reader ?
Post by oli_lab » 26 Nov 2025, 20:13
HI !
these have been updated for Macos and should be OK now, thanx for checking if they alright on you side.
It is uploaded in the addons :
Olilloscope 3ch (Olilloscope)
in the modulilab :
ADDSR V3
wavetable reader V2
wave packet V3
Velvet Noise (added the sparsity input for fun)
Wave Extractor-V2
Post by cmodica » 27 Nov 2025, 17:37
hi.
They're all okay.
But the Patch exemple "OlilloscOPe.pat" is not OK.
Post by oli_lab » 27 Nov 2025, 21:12
OK, thank you
