temporary difficulties with WIN64 installation
Announcements
Unread post by oli_lab » 18 Sep 2025, 13:08
Since few days, Windows Defender prevent Usine to launch when Usine is lauch for the first time on a computer.
To be able to launch Usine properly, this is what you should do :
go to the "bin" folder in the "Usine Win 6.0.250506" folder
then click on "usine.exe" : Usine should launch, after Windows has asked few questions...
then Usine will launch normally from the other "usine.exe" that is on the root of the "Usine Win 6.0.250506" folder as usual.
Off course this is a temporary solution, Senso will soon put another distribution online.
Unread post by oli_lab » 18 Nov 2025, 09:13
this issue has been fixed as for Usine Win 6.0.251117,
Thank you Senso !
Users browsing this forum: No registered users and 226 guests
