SOLO/MUTE Module
Ariajazz
SOLO/MUTE Module
Unread post by Ariajazz » 05 Aug 2025, 14:24
Hi all. Simple... Is there any module that allows you to SOLO and MUTE different audio sources that go to the main output?
Ariajazz
Unread post by Ariajazz » 07 Aug 2025, 21:24
180 views and no replies. where are the experts of this forum?
Unread post by cmodica » 07 Aug 2025, 21:49
Maybe in hollyday. I hope they are. 😎
Unread post by SylvainT » 11 Aug 2025, 10:40
Yes we are on vacation 😎
Unread post by oli_lab » 20 Aug 2025, 22:13
The answer is : rack settings module
Ariajazz
Unread post by Ariajazz » 27 Aug 2025, 22:28
Thanks for your reply... I get the idea but it doesn't work for me. All the audio sources are in the same patch
Unread post by grego mondo » 28 Aug 2025, 12:15
if all your sources are in the same patch then you can make a sub patch with a mix volume in it (and as many voices as you need)
and use seq switches to get array of values for muting each voice of your poly sub patch
for the solo there's a trick :
If array from solo sum = 0
Array from Mute act on mute in the volume (muting each corresponding voice of the sub patch)
but if array from solo sum > 0
then the Array from solo is used (with logical not every not selected voice would be muted)
Hope it helps
Solo-Mute.pat
(31.47 KiB) Downloaded 228 times
Unread post by grego mondo » 04 Sep 2025, 17:44
and so Ariajazz
Does it works for you ?
Unread post by oli_lab » 04 Sep 2025, 21:42
Well done Greggo, very cleverly designed !
Here's my 2cents :
Solo-Mute-Oli_Lab.pat
(139.99 KiB) Downloaded 273 times
Yours is ligther on the CPU but.
Unread post by grego mondo » 05 Sep 2025, 08:55
Yours is nice too Oli (and it calls grouped switches concept)
and the VU meters are pleasant
Users browsing this forum: No registered users and 100 guests
