Event Recorder V2 !
Event Recorder V2 !
there's a new version of the event recorder : it's with the data_lab addon ,
check the example as it is not working out of the box, it need patching to use the new preset capability
enjoy,
enjoy,
Hi and thank you Olivar.
It seems that on MAC OS X, Apple intel, none of the modules work.
The modules in the data_Lab 5 are working fine, but the modules in the data_Lab 7 (i suppose the last one) are all invalid.
And so, the "event recorder V2 exemple.wkp" doesn't work.
Have a nice day.
Have a nice day.
what is your Usine version ? macos modules are suppose to be "universal"
I'll check out soonish
It is Usine 6.0.250506 for Mac OS Intel.
thank you.
thank you.
do you have the same problem with last version of modulilab ?
It is weird as I recompile most of it at the same time.
I test it soon and i tell you.
I reloaded the data lab, it is now data_lab8, tell me if it is OK
thanks
thanks
Yes, it works now ! Great job!
But in the 'event-recorder exemple' i had to replace the module 'event recorder V2' by the new one and all connections are lost ..
I need to repatch it.
Thank you, very much, all your packs are so usefull !
Nice day.
Nice day.
Users browsing this forum: No registered users and 4 guests
