Event Recorder V2 !
Event Recorder V2 !
Unread post by oli_lab » 04 Jul 2025, 18:07
there's a new version of the event recorder : it's with the data_lab addon ,
check the example as it is not working out of the box, it need patching to use the new preset capability
enjoy,
Unread post by cmodica » 05 Jul 2025, 17:57
Hi and thank you Olivar.
It seems that on MAC OS X, Apple intel, none of the modules work.
The modules in the data_Lab 5 are working fine, but the modules in the data_Lab 7 (i suppose the last one) are all invalid.
And so, the "event recorder V2 exemple.wkp" doesn't work.
Have a nice day.
Unread post by oli_lab » 06 Jul 2025, 13:59
what is your Usine version ? macos modules are suppose to be "universal"
I'll check out soonish
Unread post by cmodica » 06 Jul 2025, 16:30
It is Usine 6.0.250506 for Mac OS Intel.
thank you.
Unread post by oli_lab » 06 Jul 2025, 22:01
do you have the same problem with last version of modulilab ?
It is weird as I recompile most of it at the same time.
Unread post by cmodica » 07 Jul 2025, 09:36
I test it soon and i tell you.
Unread post by cmodica » 07 Jul 2025, 19:39
The modulilab are OK
Unread post by oli_lab » 07 Jul 2025, 22:20
I reloaded the data lab, it is now data_lab8, tell me if it is OK
thanks
Unread post by cmodica » 08 Jul 2025, 12:08
Yes, it works now ! Great job!
But in the 'event-recorder exemple' i had to replace the module 'event recorder V2' by the new one and all connections are lost ..
I need to repatch it.
Thank you, very much, all your packs are so usefull !
Nice day.
Users browsing this forum: No registered users and 93 guests
