Is it still possible with HH6 to share patches over the lan? As in this video https://www.youtube.com/watch?v=umwe0JmBixA
Thank you
Share patches
I'm afraid this function is discountinued.
Maybe the team should delete this video ...
nevertheless it exist a multiple alternatives.
As making global array and share it on the network
Thank you for your answer Joffo. Global arrays won't be very useful in my case : I want to "duplicate" some patches, part of Usine (e.g. mixers, grid) to be able to go in the
audience when my setup is on stage , and check things. For now I use a multi monitor app (space desk) and duplicate my screen to an android tablet but , with heavy workspaces, it sometimes lags or works badly.
Global array is usefull to share parameters across network . So you can make a remote with there .
I know it could be a lillte bit fastidious
Yes, mulitmonitor apps are a good alternative, but can be tricky when there's a lot to do.
Using Global Arrays is a really good solution, easy to implement (once you have made one or two to get the idea), strong and efficient.
It can be a huge work if you want to duplicate all your wkp. But, if correctly made, you only need to build one workspace.
Best
Best
Thanks to both of you. I know Global Arrays and I'm already using them in my workspaces. Very useful indeed.
I will think about that again but I'm afraid that , in this particular case, it'd be way too long and comlpicated:-(
Have a nice week end!
