Simple patch causes Usine to crash
VictorWetzel
Unread post by VictorWetzel » 28 Mar 2024, 23:14
Hello there,
First post here !
I have a simple patch, called "cyclic-panner" : basically a surround panner with some LFO. I created this patch with Usine 5. It worked fine with beta versions of Usine 6.
Since I upgraded Usine to Usine 6 and that I upgraded my Mac, it invariably crashes Usine to use this patch. Can't see error messages.
Can someone run it on his/her machine ? It might be a weird bug, a problem in my patch, a machine dependent problem... I don't know !
Thank you !
PS : crash experienced with Usine-M-Series-6.0.231116 (beta) and Usine-MacOS-M-Series-6.0.240322
Cyclic_panner_FAULTY.pat
(42.76 KiB) Downloaded 496 times
VictorWetzel
Unread post by VictorWetzel » 05 Apr 2024, 10:36
I was able to narrow down the problem, and can provide a minimum crashing example (file is attached to this answer).
And I can also provide an error code :
[46] Error :
E901 patch process : Set Value
module : audio_pan_surround_panner
inlet : X 1
rack : 1
patch : MinimumCrashingExample-SurroundAudioPanner-2024-04-05-UsineHH6.0.240403
I tried upgrading my Usine version. I also tried coding the same patch in the last Usine 5 version available, and it exhibited the same behaviour.
Now, the patch runs fine for 20 or 30 secondes, then the above error code shows up. After a few more seconds, Usine crashes.
This behaviour didn't exist for older Usine 5 versions (something like versions that released in late 2022, november, december).
MinimumCrashingExample-SurroundAudioPanner-2024-04-05-UsineHH6.0.240403.pat
(30.28 KiB) Downloaded 435 times
VictorWetzel
Unread post by VictorWetzel » 05 Apr 2024, 10:48
Did a few more tests.
This unexpected crash happens also on Windows 11, but it takes a lot more time before the error message shows up.
I tried running an Intel release version of Usine 6 on my M1 Mac (through Rosetta), and the crash also happens, but with an additional audio drop error pointing to the patch's corresponding rack.
Unread post by senso » 09 Apr 2024, 17:57
this issue has been probably fixed in the latest version?
please send bug report by mail : support@brainmodular.com
VictorWetzel
Unread post by VictorWetzel » 10 Apr 2024, 12:56
Last update didn't solve the crash. I sent a bug report !
