Usine MacOS-Intel 5.2.230728 : plugins bug
gilkbp
Unread post by gilkbp » 17 Oct 2023, 14:28
I just installed Usine MacOS-Intel 5.2.230728 although I manage a "rescan all", Usine send me a E015 error when I try to use a VST or AU instrument. I tried different companies (Native, Arturia etc.).
I started from scratch a new download, scan etc. : no changement.
I installed the previous version Usine MacOS-Intel 5.2.230612, and all is correct. So I'll stay with the 5.2.230612 version :)
here are the last log lines :
[13:56:20] Create User Module : PluginWrapper.usr-osx64
[13:56:20] Error : Create procedure failed in :PluginWrapper Absynth 5 Stereo-vst /n module : user/n patch : patch/n rack : 1 rack
elsabi
Unread post by elsabi » 19 Oct 2023, 15:32
I have exactly the same problem ! on mac os 10.13.6. Usine MacOS-Intel 5.2.230612 works perfectly
gilkbp
Unread post by gilkbp » 26 Oct 2023, 18:32
elsabi wrote:
19 Oct 2023, 15:32
thank you for reporting that !
hgermain
Unread post by hgermain » 03 Nov 2023, 20:03
Same thing here. Ok with 612, no more plugins with the others
mac os 10.14.6
gilkbp
Unread post by gilkbp » 12 Feb 2024, 16:45
hi,
no plugin problem with Usine MacOS-Intel 5.2.231211 and MACOS 10.13.
Users browsing this forum: No registered users and 187 guests
