Artnet sends data outside of computer like OSC?
Hey There. Been a long time. Had a fun little AI fueled rabbit hole that led me back to Usine 5. I'm trying to catch Artnet to an arduino to drive LEDS using Octows2811 and teensy 4.1 with ethernet attachment. Finally got the right libraries and am seeing my arduino node on the network using ArtNetominator as well as Usine itself and am seeing something odd.... I'm seeing the artnet in real time being sent on the local machine 127.0.0.1 on port 6454, but when I look at my router through ArtNetominator, I don't see the Artnet data leaving the computer and going on the network. Am I missing something here? I am using the Color Array to Artnet Module.
so after looking at the documentation a little more carefully, i realized plots are the answer, as they have all the send out data. I made a plot, put an LED on it and then configured everything properly to the point where the test is seen on ArtNetominator on the network, and I'm getting LEDs lighting up! Now the pesky task of actually sending color to the artnet proves more difficult. I tried to point the exact IP address of the arduino and the trusty 192.168.1.255 (broadcasting IP) and nothing yet. I remain optimistic...
Edit:
Ok, now we're cooking, but more questions than answers...I am able to change the colors of the LEDS by using Direct ArtNet module and an array of numbers (ie 255;0;0 to make the 1st LED red), which I thought that's what color Array to ArtNet module was doing, but I guess not. Just had a thought. My arduino is catching an array of numbers per channel, but perhaps that's not what color array is sending to ArtNet. The input isn't a string, so its not the name of the color.... is it the hex code for the color?
Edit:
Usine use the ArtNet DMX protocol: it sends "frames" made of 512 values in the range [0..255], one value per channel. In other words it's an array of Bytes. The Direct-Artnet module fille this array and send it to the ArtNet client.
If your want to light a RGB device is on the channel 1, you have to send the array R,G,B,0,0,0,....0 (509 zeros)
Hi there,
I did some experiment with LOLIN D1 mini pro ESP8266, RGB led matrix and RGBW led
artnet thru wifi
I'm happy to share :
// pour LOLIN D1 mini pro ESP8266
// first DMX start address
#define DMXSTART 0//canal de départ -1
#include <FastLED.h> // include FastLED *before* Artnet
// Please include ArtnetWiFi.h to use Artnet on the platform
// which can use both WiFi and Ethernet
#include <ArtnetWiFi.h>
// this is also valid for other platforms which can use only WiFi
// #include <Artnet.h>
// WiFi stuff
const char* ssid = "xxxxxxxxx";
const char* pwd = "xxxxxxxxxxx";
const IPAddress ip(192, 168, 0, 112);
const IPAddress gateway(192, 168, 0, 253);
const IPAddress subnet(255, 255, 255, 0);
ArtnetWiFiReceiver artnet;
uint8_t universe = 0; // 0 - 15
// FastLED
#define NUM_LEDS 64
CRGB leds[NUM_LEDS];
const uint8_t PIN_LED_DATA = D5;
uint8_t decalage;
//for RGB LED
void LedSet(uint8_t ledNb, uint8_t redCh, uint8_t greenCh, uint8_t blueCh) {
leds[ledNb] = CRGB(redCh, greenCh, blueCh);
void setup() {
Serial.begin(115200);
delay(2000);
FastLED.addLeds<NEOPIXEL, PIN_LED_DATA>(leds, NUM_LEDS);
FastLED.setMaxPowerInVoltsAndMilliamps(5, 1000);
// WiFi stuff
WiFi.begin(ssid, pwd);
WiFi.config(ip, gateway, subnet);
while (WiFi.status() != WL_CONNECTED) {
Serial.println(".");
leds[0] = CRGB(10, 0, 0);//debug : check if fastled OK
FastLED.show(); // Envoyer les couleurs aux LED
delay(50);
leds[0] = CRGB(0, 0, 0);//debug : check if fastled OK
delay(950);
Serial.print("WiFi connected, IP = ");
Serial.println(WiFi.localIP());
leds[0] = CRGB(0, 100, 0);//debug : check if fastled OK
delay(1000);
artnet.begin();
// artnet.subscribe_net(0); // optionally you can change
// artnet.subscribe_subnet(0); // optionally you can change
artnet.shortname("8 x 8 LED panel 1");//keep < 18 char
artnet.longname("8 x 8 LED panel 1 64 RGB LED");//keep <64 char
// if Artnet packet comes to this universe, this function (lambda) is called
artnet.subscribe(universe, [&](const uint8_t* data, const uint16_t size) {
//Serial.print("lambda : artnet data (universe : ");
//Serial.print(universe);
// Serial.print(", size = ");
//Serial.print(size);
//Serial.print(") :");
// for (size_t i = 0; i < size; ++i) {
// Serial.print(data);
// Serial.print(",");
// Serial.println();
if (universe == 0) {
for (int i = 0; i < 170; i++) {
//Serial.println(i);
// get values from DMX
decalage = i * 3;
LedSet(i, data[DMXSTART + decalage], data[DMXSTART + decalage + 1], data[DMXSTART + decalage + 2]);
if (universe == 1) {
for (int i = 170; i < 256; i++) {
decalage = i * 3;
void loop() {
artnet.parse(); // check if artnet packet has come and execute callback
//leds[0] = CRGB(100, 0, 0);//debug : check if fastled OK
//leds[1] = CRGB(0, 100, 0);//debug : check if fastled OK
artnet thru wifi
// WiFi stuff
// FastLED
#define NUM_LEDS 64
uint8_t decalage;
//for RGB LED
void setup() {
delay(2000);
// WiFi stuff
delay(50);
delay(950);
delay(1000);
artnet.begin();
decalage = i * 3;
decalage = i * 3;
void loop() {
Ok! I figured it out. Thanks all! Oil_Lab thats great code there!
Users browsing this forum: No registered users and 101 guests
