launch Usine on a specific workspace
XpiR
Unread post by XpiR » 24 Apr 2023, 15:51
When I launch Usine, I'd like it to automatically load a specific workspace without any additional action (no mouse click on a recent workspace or anything else).
Is this possible with the PRO licence ?
Unread post by rlgsbt » 24 Apr 2023, 17:46
Salut François,
Dans le Dossier d'Usine, tu dois créer un sous-dossier /deploy. Si tu ne mets qu'un seul workspace dans ce dossier, il s'ouvrira automatiquement à l'ouverture d'Usine
XpiR
Unread post by XpiR » 24 Apr 2023, 18:58
Thanks for the tip, it works perfectly.
Merci ça marche !
Unread post by rlgsbt » 24 Apr 2023, 21:47
À très vite.
Sébastien
titl
Unread post by titl » 15 May 2023, 20:42
Doesn't work for me, the grid disappears it looks like a small version of usine.
Unread post by rlgsbt » 16 May 2023, 07:53
Yes, the /deploy folder open workspaces in IB mode. if you need to open a single workspace with the grid (and other option), you have to use the kiosk mode and choose your options.
http://brainmodular.com/manuals/hh5/en/ ... -tab-kiosk
titl
Unread post by titl » 16 May 2023, 12:00
Ok thanks for the answer, i never use IB.
Unfornutaly i just have a pro version.
