Bluetooth controller
Unread post by Gilsornette » 16 Feb 2023, 16:48
I've got a (very) little pedal board (M wave -chocolate) that uses a bluetooth connection. It's detected by windows as FootCtrl.
Is there a way to use it with Usine?
Thank you
Unread post by senso » 18 Feb 2023, 09:26
some of those pedal send a keyboard "key" to the active software. Did you try a simple keylearn ?
Unread post by Gilsornette » 18 Feb 2023, 11:00
Thank you for the advice. But it doesn't work, no"key" seems to be sent.
Unread post by oli_lab » 20 Feb 2023, 23:37
Unread post by Gilsornette » 22 Feb 2023, 18:03
Yes I’ve tried but I can’t receive anything. thank you
Users browsing this forum: No registered users and 445 guests
