I've got a (very) little pedal board (M wave -chocolate) that uses a bluetooth connection. It's detected by windows as FootCtrl.
Is there a way to use it with Usine?
Thank you
Bluetooth controller
- senso
some of those pedal send a keyboard "key" to the active software. Did you try a simple keylearn ?
Thank you for the advice. But it doesn't work, no"key" seems to be sent.
Did you try midi ?
https://producerhive.com/ask-the-hive/w ... ooth-midi/
Yes I’ve tried but I can’t receive anything. thank you
