“Usine MacOS-Intel 5.2.221120 2.app” can’t be opened because Apple cannot check it for malicious software.
unguitar
Unread post by unguitar » 25 Nov 2022, 22:17
I'm getting this messagge after downloading 5.2.221120 2.
Any idea?
iOS 10.14.6
Macbook Pro 13" 3,1 GHz Intel Core i5
8 GB 2133 MHz LPDDR3
thanks
______________
luca
www.unguitar.com
Unread post by SylvainT » 26 Nov 2022, 08:42
The first time you launch Usine on Mac, don't use double click. Use right.click and select open.
unguitar
Unread post by unguitar » 26 Nov 2022, 14:33
will try
SylvainT wrote:
26 Nov 2022, 08:42
______________
luca
www.unguitar.com
unguitar
Unread post by unguitar » 26 Nov 2022, 14:59
ok, it works, thank you
______________
luca
www.unguitar.com
Users browsing this forum: Google [Bot] and 62 guests
