Long file in the Grid mode
noise2sine
I need to create a project with just a long audio file around 60 minutes on one track and a second track consisting of just an automation curve sending control change . The idea is to be able for example to set at 2m30 a 63 CC value and so on .
Is it possible in the grid mode to have a detailed time vision like the one in Ableton live ? I have set the time to 60 minutes in the grid mode but i can't manage to see all the individual minutes ?
Do i just have to drag the audio file directly in the grid mode ?
What would be the best way for the midi track sending the CC values ?
Thanks !!!!
Thanks !!!!
- rlgsbt
you should create a new section for each event. Put your 60min sound on the first line and then, create different section managing your CC values.
like that :
like that :
noise2sine
Thnaks for your answer ! i can see a bit more how i can set this up then . The CC value patch used in the example, Which module did you use ? I did a little example and i couldn't find how to make the CC value fader from the patch visible in the grid section ??
Thank you !
Thank you !
- rlgsbt
in this exemple, it's just a simple fader in the rack n1. You can use anything in the grid with ctrl+shift.
have a look : http://brainmodular.com/manuals/hh5/en/learn-usine/grid
noise2sine
Can you make a screen shot of your CC change patch ?! ican't make mine working !!! Sorry but i didn't use Hollyhock for such a long time !
Thanks ! !
Thanks ! !
- rlgsbt
it's a simple fader with midi learn. In the midi section, chose your control type (CC) and the CC number. that's it
- senso
maybe you could split your file into smaller files. It will help for editing.
noise2sine
Unfortunatly i can onlywork with long file ... but i have another question ! how can i record only CC values on a midi file ?
