When shall we use the thread option in Rack Calculation Mode? Is it when there are lots of patches inside
or "big" patches with heavy cpu consumption? Or in other cases.
Thank you
Threads
This option has to be used carrefully.
You can use it effectively when you have a lot to calculate. If you have just one patch, this will not change anything, only for several patches. One thread per patch. But the reason to be carrefull is that you don't know the order of calculation. So it can't work if you have audio going from one patch to another below.
All the best
All the best
Thank you very much for this quick, and clear, answer!
and sorry for the typing error...
You're wellcome.
Just FYI, polyphonic sub-patch could also now be multithreaded, but this is the same, be carrefull, it could be worth, depending on many parameters.
Those features could be very interesting in heavy processing, but you'll need to be deeply aware of multithreading and use them with tests.
really neat that there is an option either way, thanks! would be great if automatic chain analyze option could be implemented to apply multi-threading when possible
It's impossible to predict chaining in the general case: think about buses for example.
Users browsing this forum: No registered users and 357 guests
