SWITCH in OMNI mode
Ariajazz
SWITCH in OMNI mode
Unread post by Ariajazz » 02 Aug 2022, 00:37
Hello again. The question is simple. How do I get a switch to receive cc midi messages from any midi channel (OMNI mode)?
Unread post by senso » 02 Aug 2022, 21:33
it's not possible with a simple MIDI-learn, you'll have to use a path.
I'll send you an example soon.
Ariajazz
Unread post by Ariajazz » 03 Aug 2022, 00:02
Thaks Senso for your reply. Good news, looking foward for that path example.
Ariajazz
Unread post by Ariajazz » 04 Aug 2022, 03:57
Anyone has an idea on how to do this?
Unread post by grego mondo » 04 Aug 2022, 08:57
Something like midi input / midi filter multi ?
filter num let you pass desired cc whatever the midi channel (remeber to untick "force out range in 0.1" if you use value out)
hope it helps
Unread post by senso » 04 Aug 2022, 09:25
something like that (in absolute mode)
midi-multi-filter.pat
Ariajazz
Unread post by Ariajazz » 05 Aug 2022, 04:15
Thanks Senso for the patch. I will try it ans see if is works for my needs.
Ariajazz
Unread post by Ariajazz » 06 Aug 2022, 04:33
After some modifications and tweaking the patch did its job. Now I'm able to considerably expand the capabilities of my Behringer X-TOUCH MINI external midi controller. Thanks a lot for your help.
