SWITCH in OMNI mode
SWITCH in OMNI mode
Hello again. The question is simple. How do I get a switch to receive cc midi messages from any midi channel (OMNI mode)?
it's not possible with a simple MIDI-learn, you'll have to use a path.
I'll send you an example soon.
Thaks Senso for your reply. Good news, looking foward for that path example.
Something like midi input / midi filter multi ?
filter num let you pass desired cc whatever the midi channel (remeber to untick "force out range in 0.1" if you use value out)
hope it helps
hope it helps
something like that (in absolute mode)
Thanks Senso for the patch. I will try it ans see if is works for my needs.
After some modifications and tweaking the patch did its job. Now I'm able to considerably expand the capabilities of my Behringer X-TOUCH MINI external midi controller. Thanks a lot for your help.
Users browsing this forum: Bing [Bot] and 210 guests
