Display Image
Ariajazz
Display Image
Unread post by Ariajazz » 30 Jul 2022, 01:02
Hello. Is there any way to display or open an image (jpg, png, etc.) from Usine?. I want to display on the screen an image (when need it) that graphically shows all the midi assignments and functions of an external midi controller. It would be nice if it could perform as a slide show, selecting from multiple images when desired.
Thanks.
Unread post by rlgsbt » 30 Jul 2022, 08:19
You can use "Panel image" or "Video image player" module to display PJG and PNG
Ariajazz
Unread post by Ariajazz » 30 Jul 2022, 21:23
Thanks rigsbt for you reply. I initially tried these modules with no success. After a litlle tweaking I got "video image plager" working. The only problem is that I cannot ajust the image size on the player, cosidering I'm using a 7.5 inch display I need the image to be shown almost at full screen so the information can be read. I have tried increasing resolution of images but player always display them with the same size (about 50% of screen size) and located at the center of the screen. Any tip on how to make images larger and as said before occupying the most area of the screen possible?
Ariajazz
Unread post by Ariajazz » 30 Jul 2022, 23:38
Found a solution, Resizing and repositioning both the image player and the image did the trick. Thanks anyway for you help.
Unread post by SylvainT » 01 Aug 2022, 21:50
Hi
I think it is easier to use a panel image in a popup window you can resize easily.
Ariajazz
Unread post by Ariajazz » 03 Aug 2022, 02:36
I tried panel image and did not find a way to load the images. How do you do it?
Unread post by rlgsbt » 03 Aug 2022, 08:23
image panel.pat
(51.7 KiB) Downloaded 583 times
like that. In the list manager, you just have to choose "images files" in the file type option.
Ariajazz
Unread post by Ariajazz » 15 Aug 2022, 22:16
Thanks rigsbt for the tip. Now i know how to do it.
