Two switches controlling each other not working
Hello guys, This is something I've done many times before using "pass if changed" modules but now is not working properly. When I press switch (1) the other (2) turns on but the pressed one (1) turns off after a fraction of a second. I attach the way I do it. Am I doing something wrong?
- Screenshot_1.jpg (10.69 KiB) Viewed 12825 times
Do not use the toggle input, but COMP and ON ; the 2 switches will work the same.
remind that "toggle" input expect a trigger not a switch value.
Thanks Senso for the tip, I didn't know that. Rigsbt, I'll be testing you suggestion right away.
Users browsing this forum: Google [Bot] and 30 guests
