Conductor export....
Unread post by cmodica » 20 May 2008, 17:12
It would be cool to have the possibility to export a conductor 'snap' from a workspace to another.
For example in the wokspace 'recherche' there is an interesting 'conducteur snap', 'toto'. I export this 'snap' and when i import it in the workspace 'concert mai' it import the patches on a new line and add the snap 'toto' to my conductor ....
Is it a dream ....
thanks
Unread post by senso » 21 May 2008, 13:28
actually, totally impossible because each snap shot is relative to controls which is stored with a 'Unique ID', so can't be exported.
It means that this suggestion require a very deep re-foundation of snapshots management!
Unread post by cmodica » 21 May 2008, 18:13
Of course ....
But i don't think it is a priority, just an easy way to do for me, but not essential !
Unread post by cmodica » 21 May 2008, 18:18
But perhap's it is easier to export a line, or to import few tacks simultaneously and they are automaticaly put one per track on a new line, or somethink like that ....
It is just an idea to add a patch configuration from a workspace to an other ...
Unread post by senso » 21 May 2008, 21:19
yes I'm also thinking about this kind of new features.
