Suggestion: Save conductor
My conductor currently has about 40 snapshots and growing, each snapshot basically representing a "song" for the live gigs with my band.
For every gig, I change the order of the snapshots representing our actual setlist.
So I think it would be nice if I could save the conductor (snapshot order) seperately from the workspace. So if the band says "for this gig we use setlist X" I just load it into conductor and keep going.
More economical than saving/loading the whole workspace everytime I think.
Thanks.
But if I think about it more closely I`m wondering what would happen if I load the conductor in a workspace that "doesn't fit", meaning it has totally different patches than the snapshots saved in the conductor.
Maybe Senso has an idea?
I can think about a 'save /load conductor' menu, probably not so difficult to implement.
But if you load a conductor which was not originally made for the wkp: nothing will happen (recalls are ignored).
That would be really nice and save me some work.
Oh and I certainly don't want to sound unthankfull or too demanding, but maybe while you are at reworking the conductor, there's the other idea about implementing scrollbars for the conductor.
http://www.sensomusic.com/forums/viewtopic.php?id=756
this suggestion is not dead!
but as you have noticed, there is no scrollbar in Usine.
So I need time to create a totally new interface design for Usine (skins).
This will be done after the finalization of the vst version and a small set of high priority implementation.
I think it's a good idea but :
-It means that we will have to save a conductor file for each workspace !
- What about a special function like a bank of preset for the conductor , stored with the workspace ? In this case, no confusion will be possible with loading/saving conductor.
No?
No?
let me think about it.
This sounds also like a good idea to me.moody33 wrote:I think it's a good idea but :
No?
the multi-bank conductor storage is implemented.
next release
next release
Users browsing this forum: No registered users and 122 guests
