Hi everyone.
I know i should 'RTFM', but it's a big manual, and I haven't gotten this far yet.
I have 8 speakers in my studio I'm running from a Behringer UMC-1820. I have my studio monitors plugged into the main outputs (1+2) and smaller speakers fed from the other 8 mono outputs. The smaller speakers aren't getting any signal though. Is this because I'm running the free version?
The smaller speakers are working ok in Logic Pro.
audio outputs 3-10 not receiving signal
You should first create a device with all the output you want to use. So in your studio setup you should connect your main output plus your 8 output for your small speakers.
After you add your device to the output section of your track.
Boooop!
Yup! That did it.
Thank you so much!
Yup! That did it.
Thank you so much!
Users browsing this forum: No registered users and 77 guests
