different folders for plugin presets
blugaruda
Unread post by blugaruda » 10 Apr 2021, 22:42
Hi, I'm evaluating Zynaptic's excellent Morph 2 plugin at the moment but HH4 is not remembering my presets. It turns out that the factory presets are stored in one folder and user presets in another. For some reason HH4 can't see my user presets. I've tried it on Logic Pro and it's not an issue there so I guess it's some setting in HH4. Can anyone tell me what to do about this? Thanks.
blugaruda
Unread post by blugaruda » 20 Apr 2021, 19:11
So nobody can tell me how Usine could remember my plugin presets?
blugaruda
Unread post by blugaruda » 20 Apr 2021, 22:46
OK. If anyone's reading.. I've found that if I load a VST rather than an .au the plugin remembers the preset. No idea why but there we go..
Unread post by rlgsbt » 21 Apr 2021, 07:36
Hi Blugaruda,
Welcome in Usine.
If you want Usine to record/remember your preset with a VST, you have to create an Array from the VST's parameters, a "pass if change" and then write a new preset in Usine (not with the VST)
blugaruda
Unread post by blugaruda » 22 Apr 2021, 21:14
Wow really? That's insanely complicated.. Thanks for letting me know..
Users browsing this forum: No registered users and 237 guests
