Black frame on video loop point
I made video patches the same way (a little bit different than the common player inserted by default when you drag a media on a rack) in order to play a video loop, but I have a problem: each time the video ends I see a little black frame before starting again.
Here is my rack. You will find a "play loop" switch and a "stop" button. As simple as that.
Is there someone to tell me why I have this little black frame although the common video player has not, please?
creal.
creal.
- black frame on video loop.rack
- (45.57 KiB) Downloaded 197 times
You have the same problem with the common video player.
If think it is due to video compression codec.
Have a look here :
http://www.brainmodular.com/manuals/hh5 ... deo-player
You'll find a switch called "jump to key frame" on the video player, it looks better (badly, it's not working anytime).
All the best
Have a look here :
All the best
I think that it's more an issue of Usine.
I'll post an update to correct that.
The update is online !
Hi Sylvain. Thanks for your message. I have no problem with the default video player. See my attached workspace to compare.SylvainT wrote: ↑27 Feb 2021, 14:17You have the same problem with the common video player.
Have a look here :
All the best
- 2 racks to compare video players.wkp
- (217.82 KiB) Downloaded 205 times
Waou! Thank you so much. I just tested the last Usine version and the black frame disappeared. It's smooth now
PS: maybe I'm wrong, but the last version should be named "4.1.210227" and not "4.1.200227" (otherwise, Usine can't detect a new version and some patches/racks get warning messages because built on a "newer" version, which is not the case).
date corrected
thanks
thanks
Users browsing this forum: Bing [Bot] and 17 guests
