Grid vertical zoom and delete line
Unread post by cmodica » 16 Feb 2021, 18:32
Hi all.
i hope you are fine.
Is there a vertical zoom in the Grid ?
Is there a way to delete lines ?
I can delete sections but i didn't find how to delete lines.
Unread post by rlgsbt » 17 Feb 2021, 08:04
to delete line (but it's tricky). Pull down the line and when it's the last place, then change the number of lines
Unread post by senso » 17 Feb 2021, 10:09
yes, you can't delete lines directly, and the tip above is correct.
Unread post by SylvainT » 17 Feb 2021, 10:38
Hello Cmodica,
Yes, you can zoom vertically in the grid : just put your mouse on bottom of the line header, click and drag. Double click on the line header will minimize the line. Fit size button will resize all lines to default value.
There's another idea with the grid : as you can now put almost everything in the grid, it could quickly be a real mess. You can put several items on a line, you can resize them vertically. In this case, you can choose a line for a rack and put every control on this line, so you don't need to create hundreds of lines. Expand or minimize lines to edit them comfortably.
All the best
Unread post by cmodica » 23 Feb 2021, 13:42
Thank you very much.
I knew how to enlarge a line, but I am looking for the possibility to enlarge them all at the same time. This may not be possible.
I already use this method. It is very practical and allows you to easily find your way through the grid. That's why I'm looking for a vertical zoom.
Somtimes it is usefull to see several lines enlarged at the same time.
Thank you for the trick of the number of lines.
Users browsing this forum: No registered users and 326 guests
