list manager clear list
Hello all.
I use a ListManager with a sampler to load lists of sounds. I put a Pass if Changed between the ListManager and the sampler so that the list is updated each time I add new sounds.
But if I delete the list from the ListManager, it is not deleted in the sampler. I need to make a ClearList in the sampler as well.
Is there a solution for this?
Edited:
In the latest version there's a clear list and a clear last in the sampler module ?
Wonderful ! I will test it.
I am sorry but i don't understand.
Where is the clear list that you are talking about ?
and where is the clear last module ?
oops, my fault
it's not a module, but inlets in the sampler
Yes, i know this inlet.
But i try to find a way to clear list in the List Manager and to send the clear list information to the sampler.
that's why it would be great to have a clear list input in the list manager witch can send a clear toggle to the sampler.
I will try and let you know.
It makes the job.
