I have dozens of audio files in a folder. I would like to use only one sampler for them to be played, knowing that each audio file has to be played to one specific speaker (or pair of speaker, or 3 of them).
The trigger may vary: sometimes an audio file has to be played after a counter, sometimes it has to be triggered manually, other times it will be played after receiving an OSC message or when a music just finishes.
I'm looking for an elegant way to patch. The "trigger event" must select the right audio file among the sampler file list, choose the right speaker(s) and play it through the sampler.
Maybe I have to use some "select" modules, "and" modules, the "file ister" and "file list manager" modules.
Or maybe do I have to use another method? I could use one sampler per file, but I fear to overload Usine (there will be around 150 samplers).
What do you think about that?
creal.
Sampler : choose the right audio file and play it to the right speakear(s) when receiving a trigger event
I found a solution thanls to switch groups, which is not ideal in my opinion.
You can find a patch where when we click on button "QR*" it selects the first file of the sampler (also named "QR1"), the right speaker according the routing and play the file.
It works for the moment but maybe there is a better solution to the problem.
Thanks for your help,
creal.
creal.
- QR codes.pat
- (95.58 KiB) Downloaded 452 times
What about using presets for your patch?
create listbox for the sampler and for the dispatch, then create presets, recall presets by fader or group switch
Thanks for your suggestion. In the meantime, I simplified the patch as much as possible.
You're right. Presets are the key for this kind of situations. I never used them but it's the right moment.
By any chance, did you post any tuto about using presets in HH4, Joffo? (I don't find such videos on your YT channel, but I still don't watch them all)
Thanks again,
creal.
Thanks again,
creal.
I have this one https://www.youtube.com/watch?v=5bvZP1L3sYk but it's an old one and mainly dedicated to audio samplers .
It's a good idea for a new subject indeed.
Users browsing this forum: No registered users and 112 guests
