I try to find a way to change the placement of a sound in the sourround space, according to the volume of this sound.
For example :
I hit a cymbal.
when the sound is louder than a specific volume, we can ear it on speaker 1
when the sound decrease and the volume is under the specific volume, we can ear it on speaker 3.
I'd like to have the possibility to change the placement more or less speed.
I try with an Envelope Follower and a Trajectory surround pan with a trigger to play trajectory. But it doesn't do the job correctely.
I'm sure it is not a complex patching work, but there is something that i can't find.
change Surround pan according to a thresold
- cmodica
- cmodica
I will try as soon as i can and i will tell you.
- cmodica
I test with array and Dispatch module. It seems to work fine if i adjust Attack and Release of the Env Follower.
i test with a sampler to simplify, but in the final patch, the audio In will come from an external source.
