Long random data delay
Saynom2
- New member
Hi everyone,
I would need to have a sub-patch (or maybe a script) for a long and random data delay but I don't know how to proceed.
My needs are as follows:
- a data delay that could be anywhere from 6000 to 20000 ms.
- a "generate" input that could be triggered by a button to randomize the length of this delay.
Do you think it could be doable?
By the way, I'm on HH3 if it's of any help.
Thanks in advance.
Thanks in advance.
- x.iso
well, indeed Data Delay lacks max delay parameter like Audio Delay have, so this belongs to feature suggestions. you could daisy-chain data delays, but it's a PITA to manage (for instance if you input different random delay timings on each one, overall delay would probably not change too much, but if you use same random number for timing all delays, it will make huge range difference from value to value
Saynom2
- New member
That's exactly what I tried before I posted my question here. The problem is that for some reason when I do this I get a "noisy" output. It doesn't behave like you would expect. That's really strange... :/x.iso wrote: ↑20 Jun 2020, 04:12you could daisy-chain data delays, but it's a PITA to manage (for instance if you input different random delay timings on each one, overall delay would probably not change too much, but if you use same random number for timing all delays, it will make huge range difference from value to value
- nay-seven
Have you tried something this way ? ( you can also adjust num of blocks)
Here's an example.
Limited to 20 datas (during the max time of the delay).
If you want more, increase the number of polyphonic voices of the delay sub patch.
All the best
Here's an example.
All the best
- x.iso
I've helped out with this yesterday via Discord and as it turned out regular Audio delay was enough for the task, as it allows for up to 60 seconds delay. I've also used polyphonic approach to avoid overwritting sampler before it can playback full recording made.
as for data delay, I also thought of using time counter and flow mechanics to replicate longer data delays. so it can be done, but a bit too much of a hassle compared to just having longer delay timings in Data Delay to begin with.
patch in question is attached
- x.iso
yeah, I forgot to post here, sorry about that. but your patch is useful specifically for long Data Delay, which was originally requested and could be used in various scenarios.
