I'm about to move my setup from Pc to Mac.
I expect to be able to open my setup and find everything as it was before changing the system.
Anything to be aware of from who did this step before?
Many thanks
moving Usine from Pc to Mac
No problems for your workspace's, except if you're using PC Touch screen features of course.
Export your workspace with media's, better to not lose the path's.
Audio & MIDI Devices are often renamed by mac, so some small adjustment to do.
AU version for plugin's if needed
One question for Mac users: where do I find the "Config" folder in the Mac?
I need to go there to paste the settings I copied from my PC.
This is the procedure I use each time I update Usine.
Right click on the .app then "Show Package Contents." but understand all files are not compatibles..
Users browsing this forum: No registered users and 633 guests
