Oscilloscope definition
Unread post by Gilsornette » 04 Apr 2020, 18:58
I was wondering if it was possible to get the output of the Oscilloscope module to be used in "high definition mode".
Thank you
Unread post by nay-seven » 06 Apr 2020, 14:50
maybe an idea for the suggestion forum ?
be sure to also check that use low graphic quality is disable in the setup/global
Unread post by Gilsornette » 06 Apr 2020, 17:11
Thank you for your answer. I've tried changing the graphic quality but it doesn't change a lot.
I'll suggest it.
Unread post by SylvainT » 07 Apr 2020, 15:31
Like for every module in Usine, the output definition is linked to the size of the GUI. The more the size is high, the more the output definition is increased.
Hope it helps.
Unread post by nay-seven » 08 Apr 2020, 19:37
Here a workspace the user rlgsbt send me ( he has temporary difficulties to access the forum)
oscillo2video.wkp
(102 KiB) Downloaded 823 times
Users browsing this forum: No registered users and 148 guests
