Array script not working in V4
Unread post by woodslanding » 18 Feb 2020, 09:28
This worked fine in v3. It also opened fine in v4. But after saving as v4, it doesn't work.
Any thoughts?
It is supposed to sort through the list of channels, and output a list of channel numbers and names that are fx channels. But, although there are four non-zero values for fxStatusIN, there is no output of either names or numbers. All the input data looks fine....
Oddly, it did work for names, but not numbers until I did a recompile and reset. Now it doesn't work for either. Just wondering if I have some wrong syntax that the v3 glossed over.....
Code: Select all
Const MAX = 32;
// parameters declaration
var fxStatusIN,huesIN,satsIN  : TParameter;
var ctIN : TParameter;
var fxChansOUT,ctOUT,huesOUT,satsOUT : TParameter;
var fxChans: array[1..MAX] of integer;
var hues: array[1..MAX] of single;
var sats: array[1..MAX] of single;
procedure init;
begin
  fxStatusIN := CreateParam('fx status',PtArray);
  SetIsOutput(fxStatusIN,false);
  SetMax(fxStatusIN,MAX);
  ctIn := CreateParam('ch names',PtTextfield);
  SetIsOutput(ctIn,false);
  HuesIn := CreateParam('ch hues',PtArray);
  SetIsOutput(HuesIn,false);
  SatsIn := CreateParam('ch saturations',PtArray);
  SetIsOutput(SatsIn,false);
  fxChansOUT := CreateParam('fx chs',PtArray);
  SetIsInput(fxChansOUT,false);
  SetMax(fxChansOUT,MAX);
  ctOut := CreateParam('fx prgs',PtTextfield);
  SetIsInput(ctOut,false);
  HuesOUT := CreateParam('fx hues',PtArray);
  SetIsInput(HuesOUT,false);
  satsOUT := CreateParam('fx saturations',PtArray);
  SetIsInput(SatsOUT,false);
 end;
// Callback procedure
var fxCount,len,chanNum,i : integer;
var status : integer;
var name : string;
var slIN,slOUT: TStringlist;
var hue,sat : single;
begin
    slIN.create;
    slOUT.create;
    len := GetLength(fxStatusIN);
    slIN.setCommatext(getStringValue(ctIN)); //sl count is long because of an extra comma at the end!
    fxCount := 0;
    if (slIN.count - 1 <> len) then strace('>>>ERROR---isfx count = ' + inttostr(len) + ',string count = ' + intToStr(slIN.count) + ':getFXprogramNames')
    for chanNum := 0 to len-1
    do begin
         status := trunc(GetDataArrayValue(fxStatusIN,chanNum));
         hue := GetDataArrayValue(huesIN,chanNum);
         sat := GetDataArrayValue(satsIN,chanNum);
         if status > 0 then
         begin
             fxChans[fxCount] := status;
             name := slIN.getstrings(status - 1);// status is more reliable than string number. 1 indexed.
             //strace('got value:' + name + ' for chan ' + inttostr(chanNum) + 'status ch = ' + inttostr(status));
             //strace('hue = ' + floattostr(hue));
             slOUT.add(name);
             hues[fxCount] := hue;
             sats[fxCount] := sat;
             fxCount := fxCount + 1;
         end;
     end;
     //strace('len = ' + inttostr(fxCount));
     SetLength(fxChansOUT, fxCount);
     SetLength(huesOUT,fxCount);
     SetLength(satsOUT,fxCount);
     for i := 0 to fxCount-1 do
     begin
         SetDataArrayValue(fxChansOUT,i,fxChans[i]);
         SetStringValue(ctOUT,slOUT.getCommatext());
         SetDataArrayValue(huesOUT,i,hues[i]);
         SetDataArrayValue(satsOUT,i,sats[i]);
     end;
     slIN.free;
      slOUT.free;
end;
registry.pat
(331.96 KiB) Downloaded 256 times
Unread post by woodslanding » 05 Mar 2020, 16:55
Anybody? I can't get any effects to work in my WKP without this script. Works fine in V3.... I've been through the code, it all looks like it should work, and it did before.
Unread post by nay-seven » 05 Mar 2020, 16:58
As said before, consider sending it to support@brainmodular.com
Unread post by woodslanding » 05 Mar 2020, 19:46
Okay, I have found out that this type of line:
Is no longer supported.
I made variable length arrays and set their length in the init.
BUT, I am still getting nothing from the get and set commatext methods for TStringList. Has that method changed???
[edit: nevee mind, I had commented out that line....]
ALL WORKING NOW!
cheers,
-e
Unread post by nay-seven » 05 Mar 2020, 19:49
good news !
Users browsing this forum: No registered users and 115 guests
