Minimum Velocity Filter?
schelsullivan
Hey guys, Side note: I bought Usine! Love the power and versatility!
I need to adjust midi note data code 2 (velocity) (??) to have a minimum velocity adjustment.
I just bought a Midiplus X6 Pro to add a second manual my live setup. It seems that this midi controller will send a velocity of 0 (zero) when a key is pressed softly. My piano vst detects the note on message but does not sound with a velocity of 0. My main keyboard / controller since 1988 will send a minimum velocity of 10 allowing me to play very very softly, the Midiplus X6 Pro drops notes when I play that soft.
Ive tried to use a midi in and a Change Scale to adjust the Code 2 portion of the midi input.
Help please.
Help please.
- nay-seven
Hello and Welcome schelsullivan !
You can add a MIDI transformer module after the MIDI in and adjust gain
schelsullivan
- nay-seven
yes, you're right , not efficient when velocity is 0 ( we'll check this)
best would be to set your keyboard ?
what i found in your keyboard manual:
- x.iso
I suppose you could do something like this:
schelsullivan
Yes ive checked each velocity setting on the 6x, each one exhibits same behavior. (except the max which is full vel always)
schelsullivan
The gain of the the midi transformer would work perfectly if the gain could be "inverted". I does a perfect job of limiting max velocity. But I can make it raise the min vel. Ive tried some of the Math modules but cant seem to get it to work. so close...schelsullivan wrote: ↑22 Jan 2020, 23:03I tried that but it still passes a zero velocity when played soft.
schelsullivan
- nay-seven
Try this patch:
- x.iso
it should though, look at mapper value on the screenshot, it translates incoming msg type to message type selection in Create MIDI, replicating all incoming midi except for data 2 being modified. Actually you'd need extra step to only apply Mapper Curve when Note On message is received and use MIDI Unpack right after MIDI input so that messages are not bundled up in arrays and come out in sequence as intended (that's why Note OFF didn't work). I used Mapper Curve in this case for the sake of being able to also set velocity curve. I'll send a proper patch later. Maybe even upload in Add-ons as it can be useful and it's quite a typical tool for DAW to have.schelsullivan wrote: ↑23 Jan 2020, 02:28This is very close to working. I can see code 2 on the output limited at where I set it, but this is not passing note on/off ??
schelsullivan
after looking very closely at the midi in port, Ive noticed that this MidiPlus 6x Pro controller is not actually sending a note on msg when I play softly! I confirmed this with midi ox.
https://imgur.com/l9f2tg8
(hope image works)
Line 1 of midi ox is me playing middle c softly
Line 2 of midi ox is me releasing middle c
its sending a NOTE OFF msg with a code 2 of "0"
Line 3 and line 4 are me playing a middle c more firmly
Ive been using the old korg m1 since 1987, Ive played a few modern keyboards too. Never seen anything like this before.
Is this just a terrible bug in this Chinese midi controller? Its cheap for sure, but I really like it other wise.
- nay-seven
About sharing image use the full editor of this forum and add the picture via the attachement, then click on "inline" button to insert it.
You can also activate the trace panel/MIDI in to see what's happen directly in Usine.
About your keyboard, yes, it's strange and not common, is my patch works for you ?
It looks as if whoever programmed this keyboard has misunderstood the use of velocity in Note messages: A NoteOn message (status 90 in your screenshot) with a velocity of 0 (zero) is, and has always been, a NoteOff, which MidiOx (of course) shows. In other words, the minimum velocity for a NoteOn is 1. A lot of older equipment used that for NoteOffs instead of "proper" NoteOffs (status 80 in your screenshot).
Another not very normal feature seems to be that the NoteOff velocity is a duplicate of the NoteOn velocity. (I suppose you didn't release the key just as fast as you pressed it?) As far as I know, not many keyboards have an implementation of NoteOff velocity other than as a static value, and over the years not many instruments have used varying NoteOff velocities for anything at all. In fact, it has been so little in use that in the default setup off my controller it was disabled.
schelsullivan
It fails to sound a note received with a velocity below the value set.nay-seven wrote: ↑24 Jan 2020, 09:34About sharing image use the full editor of this forum and add the picture via the attachement, then click on "inline" button to insert it.
Im exploring my options, return it, continue to try and fix it with software (midi ox is super powerful too), or just deal with and adjust my playing (not likely)
Thanks for helping
- x.iso
so, here's velocity curve/range/randomizator patch. hope it's helpful
