GRM Plugin VST not recognized and AU crashing Usine
fractalist
Unread post by fractalist » 23 Jan 2020, 00:45
I’m trying to port my workspace from V2 to V4
Plugins work so far except one, sadly the one that is central to my live set : GRM Evolution
Usine crashes as soon as I insert the AU version.
Regarding the VST one, in despite of a scan, the GRM VST plugins aren’t found by Usine / the search at all. either if they sit in their folder or in the root folder.
I tried trick Usine by putting the VST in a recognized folder ; now I can see the VST, I can add it to a patch, but the GUI is completely black when I open it.
please help I need it :-(
french innovative audiodigital tools should work together pretty well :P
Unread post by nay-seven » 23 Jan 2020, 09:14
Yes, we are in contact with GRM team, but process is slow, and we can't do anything on our side for the moment sadly
fractalist
Unread post by fractalist » 25 Jan 2020, 00:55
damned, too bad :-((
I'll contact them so that they'll know people actually need this !
Since we are at it... I change th thread name :
I have 5 more plugins not displaying their GUI : they are all from Airwindows.
they don't really have a GUI except some sliders so it's not a big deal but you might wanna know.
and in case you don't know airwindows, consider it's christmas - ten times - again
I also have another plugin pb somewhere but not sure which one, tell you later
Unread post by nay-seven » 25 Jan 2020, 09:00
About Air windows, i've install demo, only 2 of Au are visible ( 32 bits ?) , VST open but only Juce window, have you contact them ?
fractalist
Unread post by fractalist » 05 Feb 2020, 22:41
oops, haven't yet.
the goal of airwindows is to ensure maximum comptability, to fuck obsolescence's ass and maximize retrocompatiblity. this will break his heart !
not a big deal not to have the interface, but I'll tell him anyway.
One more trouble : IRCAM verb session by flux : only one channel works for the ouput in the VST. AU is fine (so ok for me but if you should know...)
fractalist
Unread post by fractalist » 09 Feb 2020, 15:24
adding to the previous post, again more problems (actually I have some troubles ith most of the plugins in mylivesetI realize) :
when loading Soundtoys Crystallizer, Usine gives me a message : "unkown paramters found in preset" (although I don't use any preset)
another plugins does that I don't know which one yet.
This might be the origin of anther problem : Usine has difficulty loading my workspace. 5-10 minutes needed. while a lighter version took a few seconds in HH2..
Loading the AU version of crystallizer instead of the VST solve the above problem and seems to make the download quicker.. but I can't display any parameters in Usine.. and the point of my set is to mainpulate them all in real time so useless..
I spent all my free time of the last 3 weeks to port my set to HH4, and unfortuantely, so far I just can't use that version to play :-(
Unread post by cmodica » 14 Feb 2020, 13:28
I have the same problem with all SoundToys plugins. It seems not to be an Hollyhock problem.
I send an email to Soundtoys this morning.
Try to send one too.
Unread post by nay-seven » 14 Feb 2020, 15:36
i test this plugin and yes, sadly no parameters visible for the AU version
VST version is a 32 bits one , so Jbridge solve the issue, the parameters are visible,
but yes i've also the message '"unkown paramters found in preset"
Ken29
Unread post by Ken29 » 16 Feb 2020, 20:05
Hi Guys,
I had this problem too. With the GRM V3.8 and HH4 on PC, the GRM tools work fine.
fractalist
Unread post by fractalist » 19 Feb 2020, 12:02
thanks for the info
on my side,
GRM 3.8 : not working on my mac.. (10.11)
Jbridge : not working on catalina to which I'll swtich (not by choice but by change of computer)..
yes soundtoys have been contacted
Unread post by nay-seven » 19 Feb 2020, 12:23
About Jbridge, not sure the dev can fine a solution cause Catalina don't accept 32bits apps anymore
unguitar
Unread post by unguitar » 12 Apr 2020, 16:20
was this issue solved?
______________
luca
www.unguitar.com
Unread post by nay-seven » 12 Apr 2020, 19:48
Grm works fine now on my latest test, as most of the plugins issues .
Unread post by cmodica » 22 Apr 2020, 14:19
Yes, thank you.
There is always a problem with soundtoys. I send them a new mail 2 weeks ago, but i have no answer.
Probaly not a good time for that.
Users browsing this forum: Google [Bot] and 205 guests
