Small HH4 niggles and suggestions
Unread post by woodslanding » 09 Jan 2020, 23:58
First off, I'm delighted with HH4. It seems quicker and more efficient, and looks better, while setting a new high for backward compatibility. Maybe Usine is growing up ;)
A few things I've noticed so far:
on my monitor, it's very hard to read the names of the midi devices. It's light grey lettering on slightly darker grey.... and the setting to not display input devices on racks is not respected... (although the output setting is.)
The Fullscreen input to the master module doesn't seem to work??
I liked the look of the old faders better when using the title on the side. The background of the text being the color of the fader is less clear than the background of the text being the same as the background of the fader. Of course, I can probably create an image file to do that....
Mentioned in an email, but putting it here for posterity.... Can we have a global option to turn off the selection rectangle? When using the IB with a touchscreen, there is no value to seeing it, but I guess I could see it being useful in patching.... it's certainly not a feature I've ever found myself wishing for.
An old request, but maybe forgotten, or else too difficult? could we have a 'show in patch' button in the inspector? Could be right next to the 'pin'. When I'm patching, I rarely need the menu on the left for anything else, so I'm constantly opening and closing it. And annoyingly, when I do open it, it is not updated to the currently selected object, so I have to go select the object again!
What I'd really like is to have that menu show up on a right click, with the first item being 'show details'. It is, after all, a contextual menu! HH has shown me what a brilliant idea the contextual menu was in the first place. I really miss the screen real estate it takes up, since I'm forever opening and closing it. I realize the context menu is used for other things in the patching window.... so... what if that menu could optionally behave as an actual menu, instead of a docked list? For me, it just doesn't get used enough to warrant the space it takes up. I guess there are times when it's nice, if you are opening a bunch of patches at once... so it would be nice to have either option.
Lastly for today: could I suggest an option in downloads to just download the exe file, where appropriate. You could call it 'upgrade from HH V 4.xxx or later' and zip it with a readMe about where to put it. With the almost daily build cycle, it would save users a lot of download time, and also take a load off your server.
cheers,
-e
Unread post by SylvainT » 10 Jan 2020, 11:07
You can easily change the color of your devices to have the good balance between background and caption.
In HH4, there're new possibilities about design : a global color was introduced for patch (subpatch, container, popup...) and a copy/paste procedure for module's "size" and "design" (you must be in god mode).
Fullscreen is working well here, even with a trigger in the input of the master module.
For your fader problem, it is also a template you can probably change. You can also easily create a snapshot to recall each time you create a new one.
For the rest, everything's fine for me.
All the best
Unread post by senso » 12 Jan 2020, 16:20
thanks for suggestions
the 'download just the exe' is impossible in the general case:
- in each update, generally several files are modified, not only the exe: library, templates, snapshots, audio files, etc. It leads to extra work to know which files have been modified.
- it's in any case impossible on MAC
Unread post by woodslanding » 17 Feb 2020, 05:54
Perhaps just make the audio and video data for the demos a separate file??? Every time I download a new version, I just go in and delete them to save space....
Unread post by woodslanding » 18 Feb 2020, 09:44
A note on the fullscreen issue:
I have a single button which is cabled to three master functions:
IB mode
Show Menu
Fullscreen mode
I have been finding that it seems to matter the order I attach the cables, in order to get all three to work. I finally managed it, but I had instances of both Fullscreen and Show Menu stop working.... any 2 cables always worked, but the 3rd one I cabled often didn't...
As mentioned elsewhere, this is a case where an absolute on/off value rather than a toggle of an unknown state would be really helpful. I would love to be able to turn all three on or all three off, rather than just switching to whatever the opposite of the current settings is....
Lastly, HOORAY for 'set scrollbar width' in the IB!!! I zeroed it out, and finally have ALL my screen real estate available, for the first time ever!
Users browsing this forum: No registered users and 110 guests
