preset manager HH4
parityflux
preset manager HH4
Unread post by parityflux » 30 Dec 2019, 06:56
I'm having trouble with the preset manager. Mostly with the workspace version of it:
If I change between workspace presets, some things change but others don't:
1) the button statuses (the MIDI/muted buttons and the main reverb buttons) do not save. They are marked "save in preset".
2) the send knobs do change
3) the patch presets change, but the names in the drop down do not (very frustrating)
All of the buttons are in the patch. The "Twin Verb Router" is a sub-patch so I can reuse it easier. The above behavior is confirmed in the other, similar racks. I also made sure that the button statuses would save within the presets and they do, but when the workspace changes the presets: no change in those buttons. This really needs some more work IMO.
I had a very similar setup in HH2 and it worked really well. The workspace preset was of course much bigger and over in the left.
Any pointers?
-John
Unread post by nay-seven » 30 Dec 2019, 09:20
If you talk about real button, it's normal, but maybe you talk about switches ?
best in those cases are to send us a workspace example at support@brainmodular.com please
parityflux
Unread post by parityflux » 30 Dec 2019, 17:57
nay-seven wrote:
30 Dec 2019, 09:20
It's a switch. My apologies. I created a small test workspace and it seems to work nearly as it should, so I am going to try clearing all of my presets and try again. When switching a workspace preset, the path preset dropdown does not change. Maybe it's not meant to change, but it would be most helpful if it did.
If I still have issues after this gig, I will send a test case for ya.
Thank you!
Users browsing this forum: No registered users and 812 guests
