rack output remote
rack output remote
Unread post by Gilsornette » 21 Nov 2019, 13:28
Is there a way to assign, in a patch, a midi remote to a rack output? Via a message or a particular module?
Thank you
Unread post by nay-seven » 22 Nov 2019, 09:28
The module usine rack settings will do the job ?
Unread post by nay-seven » 22 Nov 2019, 22:17
Maybe i misunderstood your question but you can assign a MIDI learn to a knob linked to this module this way ?
Unread post by Gilsornette » 23 Nov 2019, 15:09
My question wasn't clear enough. On loading a certain rack I'd like a midi remote to be automatically assign to the gain output of that rack. For that I could just record the rack with the midi remote asssignment, but I'd like to be able to load severall racks and that my midi remotes increment at each time (e.g controllers, for fader 1 on rack 1, fader 2 on rack 2, etc..). It could be also, for example, that loading of the rack opens a dialog box,
or something else, and if I move a fader of my BCF the corresponding controller is automatically mapped to the midi remote of the output. In other words is it possible to have access, by patching, to the menu "remote assign" of a rack.
I'm wondernig if it's clearer than before...
x.iso
Unread post by x.iso » 24 Nov 2019, 01:56
Usually something like this is done via controller scripts, which I don't think is supported in Usine. But I think I might have an idea how to do this by patching in MIDI device. I'll post example when or if I figure it out. In a mean time you can post automap controller scripts in feature suggestions.
Unread post by nay-seven » 25 Nov 2019, 09:09
ok, i understand, i suppose a polyphonic patch can maybe done, but the difficulties i see is to recognize the MIDI device used automatically
x.iso
Unread post by x.iso » 25 Nov 2019, 13:31
you can make polyphonic patch inside specific MIDI device's patch and save it. this is the kind of sub-patch you would need in it:
but, need to figure out correct CC array handling so this patch receives CC's in expected order. and you set sub-patch polyphony number to number of faders/knobs you want to use.
Unread post by Gilsornette » 25 Nov 2019, 17:28
Thank you x.iso, nay-seven! I'll have a look to that really soon and get back to you.
Unread post by SylvainT » 26 Nov 2019, 13:30
Here's a small patch for an automatic remote with the BCF
You can put it in a device.
Automatic BCF Remote.pat
(114.71 KiB) Downloaded 285 times
I made it for the 8 faders of the BCF first page. You can easily complete the patch if you need more
Unread post by Gilsornette » 26 Nov 2019, 18:25
Thank you Sylvain! I made little modifications and tht's exactly what I wanted
Users browsing this forum: Google [Bot] and 17 guests
