Export video
noise2sine
Unread post by noise2sine » 10 Oct 2019, 07:25
I have a patch playing videos , and would like to know how to record thoses vids on a video file ?
Thank you !
x.iso
Unread post by x.iso » 10 Oct 2019, 08:20
there's no option like that. maybe with OBS software
noise2sine
Unread post by noise2sine » 25 Oct 2019, 07:05
Thanks four your answer ! i will try this . Do you know if in the HH4 it will be possible to have a video rec module ? it would be a dream to be able to record video flux direct into a video file 8)
Unread post by senso » 25 Oct 2019, 08:39
you can record frame to frame with the player-image for now.
we are working on a a realtime encoder.
noise2sine
Unread post by noise2sine » 25 Oct 2019, 13:27
thanks that sound amazing ! do you have any time estimation for that ?
x.iso
Unread post by x.iso » 25 Oct 2019, 21:41
senso wrote:
25 Oct 2019, 08:39
That's great. If it will be possible to utilize hardware accelerated encoding like NVENC or Intel Quick Sync Video, it should have minimal impact on performance.
Unread post by senso » 26 Oct 2019, 11:52
we use ffmpeg library for that, it does a good job and manage hardware acceleration itself.
Users browsing this forum: No registered users and 274 guests
