Welcome to our new site and forum
Announcements
Unread post by senso » 16 Oct 2019, 13:27
Hello to the community,
We are changing many things on Sensomusic.
- Our name becomes BrainModular and our site www.brainmodular.com.
- The forum also changes the old Sensomusic Forum will be down very soon. You may encounter some trouble to login into the new forum because it was impossible to import old passwords. Just fill the forgot password field to get a new password by mail. Then, it will be possible to change it.
- We are preparing the final version of HH4, it will be out in a couple of weeks.
drakh
Unread post by drakh » 16 Oct 2019, 17:22
uii
Unread post by sm_jamieson » 18 Oct 2019, 02:35
Since the changes my Usine HH3 has decided it is not authorized and I cannot authorize it.
I have got a new password and changed it back to my old one on the new forum.
When I enter the details in the settings box, it always says "you are not correctly registered".
Also, the username box appears corrupted with:
<p>The forums are temporarily down for maintenance. Please try again in a few minutes.<br />
I suppose existing Usine configs are trying to connect to the old website - how are you going to get round that ?
Anyway, if this is not going to work for a while, please send me an activation key I can use instead.
Simon.
iococoi
Unread post by iococoi » 18 Oct 2019, 07:19
hi,
could you please take care of the spam situation...and force a secure connection u still can connect via http..
the link to the forum from the main site doesn't work either, links to "https://www.brainmodular.com/forum" instead of "https://www.brainmodular.com/forums"
best, io
Unread post by cmodica » 18 Oct 2019, 09:50
The same for here about regiter with HH3. i have a new password to register in the new forum, but now HH3 is not registered. I hope it will possible to work with HH3 even with this register problem ...
Thank you and happy to work with HH4 soon !
Unread post by senso » 18 Oct 2019, 13:53
hello,
the registration procedure issue on HH3 is fixed now.
You must enter your old (sensomusic forum) password.
sorry+++
Unread post by cmodica » 19 Oct 2019, 12:54
Cool. Thank you very much.
x.iso
Unread post by x.iso » 25 Oct 2019, 03:16
definitely need that restriction for new topics that old forum had
Unread post by senso » 25 Oct 2019, 08:42
yes I agree, but not so easy because the forum we use hasn't any option like that.
iococoi
Unread post by iococoi » 25 Oct 2019, 12:47
hi,
usually phpbb isnt that bad in handling spambots..choosing the right question for the Q+A is quite important though.."a qood question that can not be Googled"
https://www.phpbb.com/community/viewtop ... #p15058271
user registration settings
new member post limit
1
This means new accounts can only post freely after their first post has been approved.
But ideally you want to stop them registering to begin with.
Use the built in Q&A antispam to set a question that cannot be searched for. Preferably something about your board, the logo etc.
How to configure Q&A
Administration Control Panel (ACP) > Spambot countermeasures> Installed plugins > click the dropdown box and select Q&A (it will be greyed out)
Click the configure button then click add
Add your question and answer (you need a Q&A for each language you have installed) click submit
Click "back to previous page" then click "back"
Select Q&A from the dropdown box (again)
Click submit at the bottom of the page.
Done.
Unread post by senso » 26 Oct 2019, 11:51
We have applied this settings, but still spam.
I suspect that spammer are real humans... not robots.
Users browsing this forum: No registered users and 162 guests
