multitrack export
just use a 4 output device on your rack and drop the rack into the record window
- x.iso
in recorder you add your outputs (devices/racks) that you want to record to separate files. but if one output is multi-channel on it's own, it should then result in multi-channel file. So, Surround-8 'device' would output 8-channel wav file. even if your audio device doesn't support 8 channels to output.
@oli_lab: I tried with a 4 output device but I got an interleaved 4 channels file. (As said x.iso )
And I need 4 separate/mono files,or at least 2 stéréo (1-2 and 3-4) files.
got it !
what I do is record in one multitrack file then use Reaper to make stereo files with downmixing
Thank you. But I don't use Reaper... I'll try with another software (Samplitude maybe). But I was expecting to find an "internal" solution.
- nay-seven
Remember you can also drag a device directly on the record panel ?
Yes, I've done it; with a Surround 4 device , but what is recorded is an interleaved file. I also tried with a Stereo (1 and 2) device and another one routing only 3 and 4, but I got a blank file with the second one.
By the way Samplitude handles multitrack files so I have anyway a solution
- x.iso
I think if you route second device like so: 3/4 > 1/2 Then second stereo pair would work, but then you will hear all 4 channels in Stereo mixdown as you record. You may just use the fact that it's also possible to drop racks in recorder, and even if you won't use any sound output in said rack, it will record whatever sound is generated in the rack and number of channels would be dependant on how many audio outs are used in last patch of the rack (if it's in serial processing mode).
So you cold make 4 proxy racks for audio capturing purposes, send your 'master' surround to each rack and filter out specific channel in a patch for each rack, then drop said racks in recorder.
EDIT: seems like you do need some audio output device in said racks, but that's not a problem. Create 'MONO out' audio out, route just one channel to one out (1 > 1), disable it in device panel and drop it in those 'proxy' racks, then it will record your racks as mono files.
Thanks x.iso. I've tried your solution. I used a recorder module (4 channels), and I can visualize that the 4 dchannels are recorded, but when I want to save them I also got an interleaved file.Is there a way to save as separate files?
- x.iso
as I've said, each output that you put in recorded will be a separate file, so you need to set up 4 racks with a simple patch (4 audio inputs and 1 audio out, and only one of the input is connected to output according to channel that rack is representing) and mono output that is disabled in devices panel. you will probably also need to set up some 'master rack' and drop that as input for each of 4 proxy mono racks. after dropping those racks in recorder they should produce separate files, at least I've tested and got this result.
- cmodica
Wave Agent from sound devices is a usefull software. With it, you can combine x mono tracks in 1 polyphonic track or Split a x Polyphonic track into x mono track.
For exemple you can split the polyphonic track with 4 channel from Usine record into 4 mono track.
Wave Agent
i hope it help.
Wave Agent
i hope it help.
@cmodica: thank you for the info.
@x.iso:"each output that you put in recorded will be a separate file, so you need to set up 4 racks with a simple patch (4 audio inputs and 1 audio out, and only one of the input is connected to output according to channel that rack is representing) and mono output that is disabled in devices panel. you will probably also need to set up some 'master rack' and drop that as input for each of 4 proxy mono racks. after dropping those racks in recorder they should produce separate files"
> yes I did all of that and the recorder window shows me 4 tracks, so 4 mono recordings, but when I look at the list files I've got only one file (interleaved)... Am I misunderstanding something?
- x.iso
when you stop recording, you have to confirm saving the files (name it if you want to and locate), all racks should be then saved as separate files. so filename goes like this: %name%-%outputname%.wav. basically there should be as many files as there are devices/racks in recorder.
Thank you x.iso, it works fine. My mistake was that I thought I had to create a "recorder rack" with a recorder module instead of using the one of the wkp...
