Using fader for video patches
noise2sine
Unread post by noise2sine » 04 Oct 2019, 21:36
I was wondering how make simple transition like fade in and out with black between two videos on two different patches ?
Thank you !
Unread post by SylvainT » 05 Oct 2019, 12:22
noise2sine
Unread post by noise2sine » 06 Oct 2019, 18:53
Hello Sylvain,
Thank you very much for the patch ! how can i change the actual color during fade process ? Now it's yellow how can i make it black ?
Thanks again !
Unread post by SylvainT » 07 Oct 2019, 14:11
It was black on my computer.
Anyway, have a look in the patch, you'll find a "Fill Color" module. Select it and change the color to black
noise2sine
Unread post by noise2sine » 10 Oct 2019, 07:24
Thank you i find it !
