master/send channel?
tsferro
Unread post by tsferro » 11 Sep 2019, 20:50
is there a master output so I can ie throw a limiter on this to handle any clipping in a live performance?
Unread post by oli_lab » 11 Sep 2019, 23:26
there is a soft clipping option down in the audio setting menu
iococoi
Unread post by iococoi » 11 Sep 2019, 23:27
hi there,
you could drop a limiter direct in your Audio Out Device/s
or make a "Master" Rack..and send everything thru that.
tsferro
Unread post by tsferro » 12 Sep 2019, 02:15
thanks - this did the trick
x.iso
Unread post by x.iso » 12 Sep 2019, 11:24
when you do this via Device patch, you could overwrite default device patch and have this limiter there all the time in any workspace. this can also be used to add some UI elements/controls that you may want to have all the time as well, by placing stuff in this patch and assigning to display necessary components where you want them to be.
tsferro
Unread post by tsferro » 12 Sep 2019, 14:32
@x.iso I put the brick wall limiter in the Device Audio Out patch like shown above in iococoi's reply and was happy/surprised to see that this keeps the same setup for all new workspaces
Unread post by sm_jamieson » 12 Sep 2019, 20:46
Very useful to edit the audio out device. I added a MONO switch like that.
Simon.
Users browsing this forum: No registered users and 253 guests
