master/send channel?
there is a soft clipping option down in the audio setting menu
hi there,
you could drop a limiter direct in your Audio Out Device/s
or make a "Master" Rack..and send everything thru that.
when you do this via Device patch, you could overwrite default device patch and have this limiter there all the time in any workspace. this can also be used to add some UI elements/controls that you may want to have all the time as well, by placing stuff in this patch and assigning to display necessary components where you want them to be.
@x.iso I put the brick wall limiter in the Device Audio Out patch like shown above in iococoi's reply and was happy/surprised to see that this keeps the same setup for all new workspaces
Very useful to edit the audio out device. I added a MONO switch like that.
Simon.
Simon.
Users browsing this forum: No registered users and 323 guests
