Can Usine modules communicate with other tracks?
laserbeak43
Try the Get/Set Global Variable modules.
laserbeak43
i was reading about this. does this manipulate the global remote? i am clueless about what i'm supposed to do with this
I haven't really used them myself so far, but the "Global" in the module names has nothing to do with the Global Remote. It's just a way of naming a variable and assign a value to it. If I've understood Olivier correctly, you could even send audio data through these variables.
laserbeak43
sick!! but there isnt an extensive explanation of them! gonna have to experiment with some
laserbeak43
holy crap it does work! all you need to do is have the same name!!
Yes patch can comunicate with the set/get Global variable.
Also, you can access to most track info (gain,pan,aux,etc.) with the "interface control/mixer track (in&out)"
laserbeak43
sweet good to know!senso wrote:Yes patch can comunicate with the set/get Global variable.
