touchscreen Settings entry
Unread post by sm_jamieson » 01 May 2019, 14:28
I have recently started using HH3 with my new convertible laptop in "stand" mode, with the keyboard folded under,
and therefore only using the touchscreen.
In the Settings I can change values that have a slider or combi box, etc.
But there is no way to open then value entry box to enter a value (via the on-screen keyboard).
Using the mouse, a double click would open the selection box. The usual equivalent of a double click on
Windows is a long touch.
On Usine, a long touch on the Settings makes a large selection square appear (a Windows effect ?),
but nothing else happens.
Can we have a general way in Usine for a touchscreen to do either:
1. A double click (probably the best solution)
OR
2. Open the settings entry box.
Simon.
x.iso
Unread post by x.iso » 01 May 2019, 14:56
On Windows long touch is usualy equivalent to right click (the square shape indicates that). By default Usine ignores double-taps, but you can enable it under Touch settings, also there's use on-screen keyboard option, but that didn't quite work for me (although since I don't need it, I haven't tried to make it work)
There are few things that for some reason don't work with touch in HH3 - for instance the division bar for patcher (when it's not windowed) or grid is not adjustable with touch.
Unread post by sm_jamieson » 01 May 2019, 21:57
OK thanks - that is working fine with those settings.
I don't know if the on-screen keyboard is supposed to come up automatically on double-touch,
but I put an icon to switch the on-screen keyboard on the taskbar so I can just select that.
Simon.
x.iso
Unread post by x.iso » 01 May 2019, 22:55
Yeah, I also use the taskbar icon to manually open it. Windows 10 does have setting for touch-keyboard to show up automatically when text field is in focus, but it works only when keyboard is turned off or disconnected (otherwise use tablet mode). So I guess you have to enable it both in Windows and Usine.
Unread post by senso » 03 Jul 2019, 19:54
did you try /setup/use virtual keyboard option ?
normally it's made for that.
