Hey all. So i'm experimenting with video! First thing to notice is that, especially with filters and such, its a processor hungry ordeal! Any other suggestions other than "don't use them" or "lower the size or resolution"?
Second thing to notice is that when putting the video to video output creates a window that can be maximized, minimized and closed. Is there a way to:
1. Make the window header disappear or smaller for maximized view?
2. Be able to move the window from the patch using LEFT and TOP vectors?
3. Be able to stretch the video to full screen using it as a bitmap in to a BUTTON or PANEL? Or is there another module that is more video friendly?
Also, can anyone confirm whether you can share video over the share network? It has an option of making the share engine down to 5ms which would work for video, but I haven't been able to see it on the computer it is shared to.
Will be also poking around some more to see if these options are in any of the settings (so far none) and if the graphic fidelity stays if I mess with the zoom scale function.
Thanks!
Video, video, video
As far as I know, for better video performance you need to make sure codecs in your system are set up in such a way that video decoding is offloaded to GPU (even if it's integrated one, should be better performance). Also more compressed videos could perform worse, but RAW high resolution videos also could jam up the bandwidth of data to process.
Thanks for the input X.Iso! Will experiment.
Hello dimitriyc. Vidéo on hh4 Will .be more optimized
update:
If there is an IP player and a video player on different racks, the video player video does not work and won't work unless Usine restarts. I find that this happens after I save the file and load it back up again. Anyone else have this behavior?
Users browsing this forum: No registered users and 179 guests
